Joe ins Posted October 25 Report Share Posted October 25 The 10-ATS8 has developed a fault in as much as it’s showing 6 of the 8 inputs as being out of range. Is this a unit fault or a program fault. 🙈 Quote Link to comment Share on other sites More sharing options...
DanT Posted October 26 Report Share Posted October 26 Hi; The 10-ATS8 is not a Unitronics Part Number. Are you refering to the Vision Series IO-ATC8 Analog Input module? DanT Quote Link to comment Share on other sites More sharing options...
