brdle2002 Posted December 1, 2010 Report Share Posted December 1, 2010 I am using a V570 with a V200-18-E3XB and I have an analog input that is constantly reading 32767. 1) The hardware configuration is set in the program to 0-20mA 2) The jumpers are set to Current input 3) I check the input to the PLC and I see .9-24mA What am I doing wrong, where should I be looking to solve this problem? Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted December 6, 2010 Report Share Posted December 6, 2010 Hi, What do you mean by 9-24mA? what is the actual reading? Are the jumpers set to ABB? make sure the jumpers are set correctly according to the specs. Quote Link to comment Share on other sites More sharing options...
