mc controls Posted May 28, 2014 Report Share Posted May 28, 2014 I am using a Vision 1040 with the Alarm server, when the trigger bit for the alarm is active the scan time goes from 3ms to 104ms and the screen flickers and the unit is unresponsive. Once the trigger bit is cleared the scan time returns to normal. I'm using a set coil for the Alarm trigger, and have only programmed 1 alarm so far, need to do 24 more?? Does the Alarm use interrupts to check status bits?? Any help or suggestions please Vision version 9.7.0 O/S 3.8 Bin Lib 0.3.10 boot 2.2 Attached pic shows ladder, MB810 is alarm trigger Quote Link to comment Share on other sites More sharing options...
AlexUT Posted May 28, 2014 Report Share Posted May 28, 2014 Hi, There are no attached pictures. Please send your project to support@unitronics.com for review. We will run it to simulate problem. B.R. Quote Link to comment Share on other sites More sharing options...
mc controls Posted June 1, 2014 Author Report Share Posted June 1, 2014 sent it already to support but still no response. i'm under the gun to finish this project ASAP Quote Link to comment Share on other sites More sharing options...
Saragani Posted June 1, 2014 Report Share Posted June 1, 2014 Maybe you should use a "When Rise" instead of direct contact on Net 3 and 4.... Quote Link to comment Share on other sites More sharing options...
