Joesteva Posted December 18, 2015 Report Share Posted December 18, 2015 Hi, is there a way that I can Force analog I/O, especifically the Analog In value?, I'm trying to simulate my process for debugging and I've already forced the digital inputs, but I can't seem to force an analog In, In my process I need to check the level of 4 tanks and a weight scale, I get this information through 4 LT and a Weight transmitter installed in the plant but in my office I only Have one process calibrator, so it would be really helpfull if there is a way that I can Force this value. Quote Link to comment Share on other sites More sharing options...
dan Posted December 18, 2015 Report Share Posted December 18, 2015 Hi Joesteva, There is no way to force a analog input within the software without supplying current or voltage to the terminal. What I would recommend is to create a new "Test" tag, and replace the analog input in your code with this tag. Once this is done, you can change the "test" tag to simulate an incoming value. I hope you find this helpful. Thanks, Dan. Quote Link to comment Share on other sites More sharing options...
