Sign in to follow this
Boetje
Critical Error Reset PLC SDW39 1
Hello
I have a PLC error on 3 systems V570,
What is the corrosion of that
I have no Ethernet connection
On the eternet page ( info mode )
Below the IP address
Hi Boetje,
Are you using the Ethernet functionality in your applicaiton?
Did you set TCP/IP card Init ?
Please make sure that the IP address, Subnet Mask and default gateway have legal values. (If you do not use the Ethernet you can set the IP settings to default in Info mode)
Does this error disapears after resseting the PLC?
