MattP_Mac Posted February 22, 2017 Report Share Posted February 22, 2017 Hi, I am new to using VisiLogic and have a V570 for my project. I am trying to understand how to integrate the sensor block with my project. I've previously only used this sensor blocks with AB PLCs. Is this possible with a V570? Does anyone have some experience doing this? I will be using Ethernet/IP to communicate between the controller and the sensor block, I am just unsure how to read/write values from individual ports/addresses on the sensor blocks. Any help is appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
Cam Posted February 22, 2017 Report Share Posted February 22, 2017 (edited) Hi Matt, The Vision series does not support Ethernet IP communication, you'd have to move to a UniStream in order to utilize Ethernet/IP. We can provide an example project specifically for UniStream with a Murr 55086 if needed. Cam Edited February 22, 2017 by Cam Quote Link to comment Share on other sites More sharing options...
