JOTA Posted March 1, 2017 Report Share Posted March 1, 2017 Hello: I ve been working in an application in which I need to show some HOURMETERS from working motors. My application is been developed in a V1210 unit, and I am using VISILOGIC version 9.8.31 As I see, it is supposed to be easy. Whle the starting motor order is held ON, the hourmeter should count up time. I want to show the numbers as the image attached. This is, the counter will count up to 99999,9 until RESET to 0000 So my prupose to do this in the network image attached, Well, I also used the VIRTUAL PLC tool to test it, but it seems not to work. In the simulation I can see the 1 second pulses, but the counter does not increment (or at least is not showing it). So, can some tell me what I am doing wrong? or the problem is the simulator? Hope you can help, Joaquin Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 1, 2017 MVP 2023 Report Share Posted March 1, 2017 The key is to never reset your seconds. A DW will hold 136 years of seconds. Your calculation is not as simple as it sounds, as you want a fractional hour display. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
