Don2015 Posted March 16, 2017 Report Share Posted March 16, 2017 Ok, I thought it be better to start a new topic then to continue in the other one. I thought everything was going great but today I see the remote operator trying to do it's thing by trying to reconnect, but it just keeps looping without connecting, so I thought I better look into the PLC, and I added the V700 Ethernet read function and put in the value of #22 and got the output value of 23 which is good then I put the input to #21 and I got back the value of 20. That means any value other then 0 I'm supposed to check with Unitronics. Thanks, Don Quote Link to comment Share on other sites More sharing options...
Ofir Posted March 16, 2017 Report Share Posted March 16, 2017 Hi, Which socket number are you using and how did you set it up? What do you see on the main screen of Remote Operator when trying to connect? Do you get any error message? Please make sure you are not using this socket anywhere in the program for other purpose. Make sure to set one of the sockets to TCP slave and set a PLC name. Open Remote Operator as administrator --> select TCP call, configure the IP address, port number and PLC name. You will need also to create or import the cache file. Quote Link to comment Share on other sites More sharing options...
Don2015 Posted March 16, 2017 Author Report Share Posted March 16, 2017 Hi Ofir, I'm using socket 6 & 7 with both set to the default settings TCP and port 20262 and 20263 respectively. I have a feeling that the value of 20 from Ethernet read means that the Re-Connect on Error is on, as I have both connections running again with that value and I'm running both remotes as Administrator. I really believe that this problem has nothing to do with the PLC or the Remote Operator program as it has more to do with something going on with our wireless network in our plant. But at least I learned a few things. almost forgot the PLC name is "Andon". As this is a Andon system that has two large screen TV's connected to the V700 PLC. Thanks, Don Quote Link to comment Share on other sites More sharing options...
Ofir Posted March 18, 2017 Report Share Posted March 18, 2017 Glad to hear you got it working! BTW you can also try to increase the time out in the Remote Operator configuration if you suspect there can be a delay in the network. Quote Link to comment Share on other sites More sharing options...
