mrdegold Posted March 28, 2018 Report Share Posted March 28, 2018 Hello all I've just started revisiting a Vision V570 project that I had completed a couple of years ago. I am planning on adding some additional components to the V570 system. However when I start the Visilogic software. I get an error of which a screen shot is attached as Startup Error. Also when I try to connect to the V570 I get an additional error I called USB Driver Install error. I guess my starting point is 1) Does anyone know what the attached errors mean? 2) How do I get by the errors? Thank you for you help MRDEGOLD Startup Error.pdf USB Driver Install Error.pdf Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted March 29, 2018 MVP 2023 Report Share Posted March 29, 2018 I'd initially be trying an uninstall/resintall. I am guessing that a Win update in the meantime has caused the failures. Make sure you have your user program(s) stored safely. If the uninstall/reinstall doesn't first work ok, do the uninstall again and run a registry cleaner before restarting and then installing. Don't forget the need to install and run as administrator. cheers, Aus Quote Link to comment Share on other sites More sharing options...
