t0r3r0s Posted February 25, 2019 Report Share Posted February 25, 2019 Greatings Can someone explane me how can I measuring lenght with encoder , i have problem with reset value of encoder I can reset only on Z of encoder but i do linearization of encoder and my circle on encoder 1 revolution have 1000 impulse it is 200 mm for example I need lenght of 350mm can someone explane me how can i make it Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted February 25, 2019 Report Share Posted February 25, 2019 . Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted February 25, 2019 Report Share Posted February 25, 2019 So if your getting 200 mm out of 1000 counts then each count is 5mm. So to get 350mm your target is 1750 counts. Just divide the output by 5 to get your mm. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted February 26, 2019 Author Report Share Posted February 26, 2019 6 hours ago, viscoelastic said: So if your getting 200 mm out of 1000 counts then each count is 5mm. So to get 350mm your target is 1750 counts. Just divide the output by 5 to get your mm. ok that but how reset my counting of encoder i use v700 encoder have a b z . when i count 350mm i set some bit , and i need encoder set to 0 ? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted February 26, 2019 MVP 2023 Report Share Posted February 26, 2019 7 hours ago, viscoelastic said: So if your getting 200 mm out of 1000 counts then each count is 5mm. Uhmmm. Not being picky, but doesn't getting 200mm out of 1000 counts mean that 1 count = 0.2mm , and subsequent maths should be based on that. You look like you've got the target correct, Visco, just a little bit more coffee needed on the other relationship. 😉 Other MLs immediately storing the encoder's current count can be used and manipulated, thus not upsetting the main encoder count at all. cheers, Aus Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted March 1, 2019 Author Report Share Posted March 1, 2019 On 2/26/2019 at 8:07 AM, Ausman said: Uhmmm. Not being picky, but doesn't getting 200mm out of 1000 counts mean that 1 count = 0.2mm , and subsequent maths should be based on that. You look like you've got the target correct, Visco, just a little bit more coffee needed on the other relationship. 😉 Other MLs immediately storing the encoder's current count can be used and manipulated, thus not upsetting the main encoder count at all. cheers, Aus have you some example for that ? I can use ML variable to store old and new value of encoder , If my target value is same like value of encoder i stop encoder and do other function Quote Link to comment Share on other sites More sharing options...
