Hi,
I have to install my program every time I turn on my v570.
I don't have a SD card installed - would it solve the problem if I installed a SD card?
Gerard
Hi gerard339,
Please review Help->Downloading/Uploading a Project.
It explain your situation.
1. Check backup battery compartment. Battery should be installed right way.
*New PLC (from the box) include backup battery in plastic bug.
2. Check battery voltage. For new battery it should be between 3.2V...3.1V. 2.8V is critical minimum.
*When measure battery voltage by digital multimeter, there is no load, and even bad (discharged) battery will show voltage in accepted range..
3. Check SB 8 - Battery Low. If it is '1', battery should be replaced.
4. Use  "Download All & Burn" download option.
*PLC registers content may be random, but project will run.
B.R.
