Walkerok Posted May 31, 2011 Report Share Posted May 31, 2011 I am working with a V350. I am looking for a way to keep certain button types more attractive on screen and allow for different shapes. Specifically, when I have a tall but narrow number or password entry button, I can find no way to make the text wrap down the button so I can get a decent description on the button. I looked for a way to use a simple button (which does allow multiple text lines) and then link that through the ladder to bring up a password entry screen, but if this functionality is there I could not find it. For now what I have ended up doing is using a button to link me to a dedicated password entry screen so I can keep the attractiveness and functionality of a more verbose description on the main screen. While this works, it seems like it should be unnecessary. Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted June 1, 2011 Report Share Posted June 1, 2011 Hello,<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"> I hope I understand your goal… See the attached files. you can produce your own graphic button and import it as image. Then you can put a text and link it to any operand. If you have any example please let me know…. Cheers, Quote Link to comment Share on other sites More sharing options...
Walkerok Posted June 3, 2011 Author Report Share Posted June 3, 2011 Hi, Thank you for the response, but I am looking specifically to make the button you can create on screen for number or password entry look better. There is no way to attach a .JPG image that I can figure out for this type on command button. I see nothing available except if the button is pressed, not pressed, or flat and only a single line of text with no multiline capability as the only option for this type of button. If you look at the button to the right I have shown this as a simple button and not a number or password entry to show what I want to show on screen. If instead I used a number or password button I would be blocked for successfully making this long of a description with multiline text. Thank You Keith Quote Link to comment Share on other sites More sharing options...
Walkerok Posted June 14, 2011 Author Report Share Posted June 14, 2011 I am still looking for a little help here. Am I missing something on not seeing the ability to put specialized artword on a number or password entry? Thank You Keith Quote Link to comment Share on other sites More sharing options...
