Sign in to follow this
sandip B patel
Accuracy in Reading Pressure
Dear Sir
I am using unistream  PLC  with analogue module wbc1 and i am reading 4 - 20 mA with respect to pressure 0 - 225 bar
but reading pressure is delay and pressure going overflow up to 10 bar
i set noice reduction is 50 hz
and sw sooming is none
so please suggest me  how to reduce is problem
waiting for reply
Please elaborate - if you monitor the pressure online it lags the actual pressure?
How can you tell and how much is it delayed?
dear sair,
For Example , when i stop Pressure valve at 80 bar in manual mode ,the pressure in HMI is going up to 90 bar
and also in analogue pressure gauge
so please give the best solution for it.
So what you're saying is the process pressure keeps rising after you shut the valve.  Like its got a spring in it.
I don't think this is a PLC problem, as the HMI and the gauge agree.  If you observe the process when the valve closes, does the gauge say 80 or 90?
What's probably happening is you have some stored energy in the system somewhere in the form of an air bubble or the valve isn't closing quickly enough to clamp the pressure at the setpoint you want.  Without being there to look at it I can only guess.
If the overshoot is always 10 bar or it's predictably linear in some way, I'd modify the logic to shut the valve sooner based on actual observed (empirical) process data.
