powertechTN Posted August 10, 2011 Report Share Posted August 10, 2011 When I attempt to open Visilogics, I receive a run time 91 error. I have had this program open numerous times over the last few days as I developed a new project. I have several revisions saved of the project and all fail to open with this same error. I am assuming the cure is the old tried and true Unitronics method of saving backups, deleting/uninstalling Visilogics, then reloading again? Quote Link to comment Share on other sites More sharing options...
Ofir Posted August 10, 2011 Report Share Posted August 10, 2011 Hi, Try first to Close VisiLogic and delete the file Current_OPLC.udb from C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\DB. Launch the application again. If you still get the same error then Reinstall Visilogic. 1 Quote Link to comment Share on other sites More sharing options...
powertechTN Posted August 10, 2011 Author Report Share Posted August 10, 2011 Thanks. I tried to delete the current object but to no avail. Now I am doing the reinstall. Again. For the fourth time since starting to use Visilogics. I got an idea, why not include a delete/boot/reinstall button on version 71197.3.12 of Visilogics, or which ever rev is next? Get the idea, very dissatisfied end user out here. VERY DISSATISFIED. I heard many people comment that Unitronics has great support, and I agree for the most part. But I would far rather have one reliable automobile than a garage full of the best mechanics! Quote Link to comment Share on other sites More sharing options...
Walkerok Posted August 10, 2011 Report Share Posted August 10, 2011 The reason you are getting the message is the propbably same reason I got that same error two days ago. If you are running Vista or windows 7 you more than likely had a windows update recently (since the last time you used Visilogic program). If your computer is like mine the automatic update reset my UAC to on without my permission. Just go back into UAC and turn it back off. I do not know why this happens but it has happened twice on my work computer in the last 6 months. Keith 1 Quote Link to comment Share on other sites More sharing options...
