Bisku Posted April 1 Report Share Posted April 1 On this forum's frontpage there is a text with a link to a pdf-file called "Cybersecurity Measures for Vision and Samba Controllers ". For detailed instructions on upgrading and implementing the recommended security measures, please Click Here or contact directly to our technical support team. Within that PDF-file there is another link heading to an updated documentation for the .net-driver: unitronics_communication_driver_for_dot_net.pdf (unitronicsplc.com) I tried to implement the caching of password like described in chap. 6. But that command isn't included in my current .net-drivers. I then downloaded the .net-drivers from the unitronics homepage at https://www.unitronicsplc.com/software-visilogic-for-programmable-controllers/ -> programming tools for developers -> .NET-driver. But I can only get the "old" .net-driver from 2015 from that webpage. Where can I obtain the current .net-drivers the new documentation is relating to? Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 1 Report Share Posted April 1 You can get an updated version of the DLL if you install Remote Operator. However, I have fixed and updated few things since then, so here is the latest version. This is the compiled dll (compiled as x86), and it requires .Net 4.7.2 (Unlike the old versions that worked with older .Net frameworks). If you need an Any CPU version, then tell me. The new communication driver references the Unitronics.ComDriver.Security.dll It also references the System.Data.SQLite.dll (which uses the interop dlls under the x86 and x64 folders. You will need those files in the same structure). The SQLite dll allows you to use the built-in SQLitePasswordStorage. You can write your own password storage (like saving it in the registry, saving it into a text file, etc), by just implementing an interface. Quote Link to comment Share on other sites More sharing options...
Bisku Posted April 1 Author Report Share Posted April 1 Hi Saragani, first of all many thanks for your support. Unfortunately, I get some errors during compilation now: Error BC30652: Reference required to assembly 'Unitronics.ComDriver, Version=1.0.0.67, Culture=neutral, PublicKeyToken=878e3ff5e143a403' containing the type 'PLC'. I think I know the reason: Im am also using the unitronics.datatables.dll. Before I updated the ComDriver I could use the PLC existing connection by using a line like 'Dim Datenbanken = New Unitronics.DataTables.DataTables(SPS, DataTablesReadOptions.StructureAndValues)' where the variable "SPS" was initiated with ComDriver priviously. This way I could always go back and forth between reading memory values and datatable-entries without have to close the connection and reconnect every time. Is there some workaround so I can still use my old code or do I really have to disconnect and reconnect every time I switch from reading/writing memory values to access database-retries? Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 2 Report Share Posted April 2 I will compile you a newer version of the Unitronics.DataTables dll The old dll was using an old version of the .Net framework, so it cannot reference a new one without being recompiled. Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 2 Report Share Posted April 2 Hi, here is the recompiled dlls. This version should be Any CPU Unitronics Communication Driver.zip Quote Link to comment Share on other sites More sharing options...
Bisku Posted April 4 Author Report Share Posted April 4 Thank you so much, Saragani. Works like charm. I feel a bit uncomfortable asking and I hope I'm not doing too much work... But if you could also compile the RemoteOperator.dll as anyCPU, then my collection would be complete. 😉 Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 4 Report Share Posted April 4 Sure. Update me if it works. Unitronics.RemoteOperator.zip Quote Link to comment Share on other sites More sharing options...
Bisku Posted April 4 Author Report Share Posted April 4 Unfortunately it raises a new error message, but I am not sure why. I am referencing both the new communication driver and the latest unitronics.remoteoperator.dll in my project. The warning regaring AnyCPU and x86 mismatch are gone, so the new dlls are all anyCPU now. Thanks for that. But I do get the same old BC30652 error message, now regarding the new remoteoperator.dll: Error BC30652: Reference required to assembly 'Unitronics.ComDriver, Version=1.0.0.91, Culture=neutral, PublicKeyToken=null' containing the type 'PLC'. Add one to your project. However, the unitronics.ComDriver is included as reference and when I check it's properties within Visual Studio, then it does itentify as version 1.0.0.91. Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 7 Report Share Posted April 7 I'm not sure what's causing this problem. I've recompiled both dlls together again. See if it makes any difference when using the recompiled ones. Also make sure that your project is compiled with .Net 4.7.2 or newer Recompiled.zip Quote Link to comment Share on other sites More sharing options...
Bisku Posted April 7 Author Report Share Posted April 7 Thank you very much, Saragni. The issue has been resolved, and my program now compiles without any error messages. Many thanks for the excellent support! Quote Link to comment Share on other sites More sharing options...
