Ruby Posted April 18 Report Share Posted April 18 Hello, first of all, sorry for my English. Today, when I turn it on, my plc gives this error message and I don't know what it could be, can someone help me? Thank you. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 18 MVP 2023 Report Share Posted April 18 It's telling you what the problem is: "Stop reason ; No Application" This means exactly what it says, there is no application in the PLC. This can be caused by several things, but most likely due to removing power from the PLC with no battery or a dead battery. The solution is to replace the battery and reload the application from VisiLogic. Quote Link to comment Share on other sites More sharing options...
Ruby Posted April 19 Author Report Share Posted April 19 Gracias!. Quote Link to comment Share on other sites More sharing options...
