Bill Posted January 9, 2012 Report Share Posted January 9, 2012 Hi, Probably a simple answer to my question. I am using a v130 and i and trying to link a data table to be displayed on my HMI. watched webinars, read all HMI help manuals, and found nothing to help me with this. I have all displays set up but not sure how to pull from the DT. Any help or suggestions on where to find this info would be much appreciated. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted January 9, 2012 MVP 2014 Report Share Posted January 9, 2012 Hi, Probably a simple answer to my question. I am using a v130 and i and trying to link a data table to be displayed on my HMI. watched webinars, read all HMI help manuals, and found nothing to help me with this. I have all displays set up but not sure how to pull from the DT. Any help or suggestions on where to find this info would be much appreciated. Hi Bill, See example attached, it is for a V570 and has some extra stuff in it, but the main point is to provide a link between the HMI screens and a data table. I hope it helps. Recipe to DT example.vlp Quote Link to comment Share on other sites More sharing options...
TT_ZX Posted January 11, 2012 Report Share Posted January 11, 2012 So basically you cannot link the data tables directly to the HMI. You have to load the data into an operand (MI etc) and then link this to the HMI. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted January 12, 2012 MVP 2014 Report Share Posted January 12, 2012 Yes, you are correct. There is no HMI widget for directly accessing data table contents. Quote Link to comment Share on other sites More sharing options...
Bill Posted January 17, 2012 Author Report Share Posted January 17, 2012 Got it guys thanks for the help, and feedback. Becoming more proficient at this stuff one Net at a time. Thanks, Bill Quote Link to comment Share on other sites More sharing options...
