BenB Posted January 25, 2012 Report Share Posted January 25, 2012 I have a program made for a v350 controller. I want to take this same program and make it run on a v1210. So far I have opened the v350 file and changed the HW Config to a v1210. The HMI display shows up as the same size as it would on the v350. I am wondering if there is an easy way to make the display show over the full screen of the v1210 without having to individually make every section of the display larger. Thanks, BenB Quote Link to comment Share on other sites More sharing options...
Emil Posted January 25, 2012 Report Share Posted January 25, 2012 Hi Bob, I'm sure you made the most beautiful displays for V350. Now - do you think if you just increase them by 4 they will remain still beauty? Quote Link to comment Share on other sites More sharing options...
BenB Posted January 25, 2012 Author Report Share Posted January 25, 2012 That was my first thought, but when I do that all of the lay out gets distorted. Ideally what I want to do is to select every element and just expand the whole thing at once. Quote Link to comment Share on other sites More sharing options...
