Actually, UniCAN is a Master/slave network of sorts. Whenever you put a UniCan Send block in, you are making that unit a master. The CheckAlive blocks make sure the "slave" is available. You will probably have a Send block in the RC1 for inputs, and a Send block in either the 570 or the 260 for the outputs in the RC1. If you post a more detailed data transfer scheme between all units we can give you a more detailed answer.
