OLAF Posted April 12, 2012 Report Share Posted April 12, 2012 We are having some V280 PLC's in use that are logging data into a table. For the follow up of these units it would be easier to receive the logged data once per day attached to an e-mail. I know how to do this with the enhanced controllers (via SD card files), but is there also a way to send complete data tables out by mail? Thanks for a short feedback. Olaf Quote Link to comment Share on other sites More sharing options...
Ofir Posted April 15, 2012 Report Share Posted April 15, 2012 Hi, You can send email from the V280 but of course there is no option to use attachments since V280 does not support SD. Anyway you can create ASCII vector with all the data. You can use string functions such as "NUM to ASCII" and "Insert String to String" to create the vector. (Also in order to go line down you can use CR+LF characters) You can send up to 800 characters in the mail content. Quote Link to comment Share on other sites More sharing options...
