BORIS Posted May 28, 2012 Report Share Posted May 28, 2012 Hello! I am a new member on this forum and I have a problem with high speed conter .In hardware configuratios I choose a high speed counter with reset ( input I1 whitch is next to high speed counter( I0 ) is a reset for counter, or not?). I am programing a Vision 120 (v 120-22-t2c) Can somebody help me? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 29, 2012 MVP 2021 Report Share Posted May 29, 2012 Could you upload your file so we can see what you've done so far? Quote Link to comment Share on other sites More sharing options...
BORIS Posted May 29, 2012 Author Report Share Posted May 29, 2012 Hello! Thank you for such quick reply. My project is attach bellow, I hope. Fist file is normal, second one is zipp file. hzmen.vlphzmen.zip I will use this high speed counter for cutting four diferent lenght of paper.( lenght will be preddetermined with switch ,3100 mm, 2800 mm , 2500 mm and 2280 mm) Lenght for paper will be editable on screen. Before I work with Easy soft pro 6 from Moeller. Unitronics have better displays and manny other options(intigers...) so now I tray this simple projects with Unitronics. Best regards Boris Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 30, 2012 MVP 2021 Report Share Posted May 30, 2012 Look at what I've done here and let us know what questions you have. You've got some more work to do adding multiple presets and a switch, but it shouldn't be too hard. Joe T. hzmen JT.vlp Quote Link to comment Share on other sites More sharing options...
BORIS Posted May 30, 2012 Author Report Share Posted May 30, 2012 Thank you very much for your solution.Yes I have some work to do, but all project is based on this counter . So one more time THANK YOU. I am from Slovenia and you must forgive me for my english. Best regards BORIS Quote Link to comment Share on other sites More sharing options...
BORIS Posted November 9, 2012 Author Report Share Posted November 9, 2012 Hello! I have finished the last projects with HIGH SPEED COUNTER and I am very pleased with Unitronics. Cutting machine is working properly. Now I start a new project with V130-33-T2 on witch is attatch an ultrasonic sensor and I have a problem with reading value 4-20mA input. The sensor is working properly (measuring with instrument-current is changing, if I moving sensor). The sensor is also work properly - led lamp is blinking.On hardware configurtion I am determine 4-20mA and MI0 ultrasonic sensor, jumper JP5 change to B (ANALOG INPUT), jumper JP3 to B (CURRENT), but the value on MI0 is still 0. Best regards BORIS Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 10, 2012 MVP 2021 Report Share Posted November 10, 2012 Boris- Upload the program for this one so we can have a look. Joe T. Quote Link to comment Share on other sites More sharing options...
BORIS Posted November 12, 2012 Author Report Share Posted November 12, 2012 Hello! Here is the program. Best regards Boris ANALOGNI VHOD UZ SONDA.vlp Quote Link to comment Share on other sites More sharing options...
Damian Posted November 12, 2012 Report Share Posted November 12, 2012 You have X1 and Y1 swapped in your linearize function. Quote Link to comment Share on other sites More sharing options...
