Kerry Posted June 3, 2012 Report Share Posted June 3, 2012 How do I access a PLC with Ethernet Card and static IP adress from the Internet? Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted June 3, 2012 MVP 2014 Report Share Posted June 3, 2012 If the device is vivible (you have a public IP) then you should be able to access it from any internet-connected PC, just by putting its IP address and PLC name into Visilogic. However, it is unlikely that IP address of the PLC will be public, unless you have gone to some trouble to set it up that way. Can you clarify how the PLC is connected to the internet? Quote Link to comment Share on other sites More sharing options...
Damian Posted June 4, 2012 Report Share Posted June 4, 2012 Take a look at EWON. http://www.ewon.biz/en/home.html Quote Link to comment Share on other sites More sharing options...
