Deke Posted June 24, 2012 Report Share Posted June 24, 2012 Hi, Recently I noticed that when I removed an image from an application it messed up the other image that was still in the application. I had to remove the messed up image download again without it, then paste it back and download again to fix it. This is on the V1210. Software Version 9.4.0 Deke Quote Link to comment Share on other sites More sharing options...
TT_ZX Posted June 27, 2012 Report Share Posted June 27, 2012 I've had a corrupted background image (after changing it) once since upgrading to 9.4 on a v1040. I fixed it the same way you did. Quote Link to comment Share on other sites More sharing options...
