External Moderators Nacho Posted July 9, 2012 External Moderators Report Share Posted July 9, 2012 I have a V350 with trends and csv to SD. It works well but sometimes when the customer switch on the PLC we see the SB217=0. If you remove the SD and insert again the error is the same. I have seen that the only way to back to run is remove SD from OPLC, to insert in a PC doing nothing more and back to the OPLC. The application is a datalogger, if we have problems with the SD we will have a serious problem. Any idea to resolve it? Quote Link to comment Share on other sites More sharing options...
