Guest Vanderli Souza Posted July 23, 2012 Report Share Posted July 23, 2012 Hello!!! I need help to transform a program HMI model for V530 V570 If possible send me step by step. Quote Link to comment Share on other sites More sharing options...
Walkerok Posted July 23, 2012 Report Share Posted July 23, 2012 The process is simple. Open your V530 project in Visilogic. Click on the "Project" tab up top Highlight on the convert to color item in the drop down list move over and click on "V570" from the list that will appear when you have "convert to color" highlighted Then a box will pop up describing to you what limitations are for the conversion (click on OK) The you will be asked if you want to save changes to your original V530 program (do what needs to be done) After you chose to save the original program or not it will begin the conversion. (The conversion will take a couple of minutes) Save the converted file into a new file name and set up your hardware as you need to for a V570 and whatever snap IO or expansions you have. You will need to go through the program screens and rework certain items so that it will look OK on your screen and certain functions won't translate correctly so do testing to make sure what you want to happen actually will after the conversion, but you are done converting. Keith Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 24, 2012 MVP 2021 Report Share Posted July 24, 2012 Under the "Project" Menu choose "Convert Project to Color" and select V570. Read the notifications - you may have to re-draw some of your items. Joe T. Quote Link to comment Share on other sites More sharing options...
