TODDSTER Posted July 25, 2012 Report Share Posted July 25, 2012 I get the attached error occasionally when in Online mode and monitoring my program and then get booted out. Any idea what it means and what causes it? Quote Link to comment Share on other sites More sharing options...
Walkerok Posted July 25, 2012 Report Share Posted July 25, 2012 Your USB to serial converter is hanging up and when that happens you get the message you do. If you look at the post http://forum.unitronics.com/index.php?/topic/1605-communications-stop-when-a-variable-frequency-drive-in-use/ This is the same problem you are having. The problem was only solved by either going directly to a serial port (not so avaialable any more) or to change the USB to serial converter to a different type/brand. Keith Quote Link to comment Share on other sites More sharing options...
TODDSTER Posted July 27, 2012 Author Report Share Posted July 27, 2012 Thanks for spending your time tracking down the problem and pointing me to that topic. I'm not sure how I missed it, since I visit the forum almost every day. I have been using the same USB-serial convertor since I started using Visilogic back in 2008 and hadn't seen the error shown above until I downloaded/installed version 9.4.0. Although I do remember getting a "has encountered an error and needs to close" message at times in the past while monitoring the PLC. Perhaps those are related to the same cause. I tried Online mode with and without the power adaptor attached to the computer. I got the error both ways. I did some searching and found out that the convertor I use has the FTDI chip. Perhaps I just need a different brand. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted July 28, 2012 Report Share Posted July 28, 2012 I had same issue a few months ago, using USB-serial converter I was using for years with no problem. And yes, problem was with converter. Just replaced and everything works fine to me since then. Quote Link to comment Share on other sites More sharing options...
