joeschu Posted July 30, 2012 Report Share Posted July 30, 2012 I have a Vision 290 that the display is bad and is need of replacement. I want to swap it with a new Vision 290. What is the appropriate procedure to follow to make sure I end up with the exact program and data entact? I do not have a SD port available on on this hardware. I appologize if this has been posted. I did my best to search the forum for this conversation. regards, Joe Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 30, 2012 MVP 2021 Report Share Posted July 30, 2012 Hopefully you have the program; if not, try to upload it. The next step is to use Remote Access to read all the data in the RAM and export it to Excel. Load the program into your new V290 and then use Remote Access again to import and download all the RAM values. Joe T. Quote Link to comment Share on other sites More sharing options...
