rich Posted August 5, 2012 Report Share Posted August 5, 2012 Hi all, Just started usuing Unitronics PLC/HMI, inparticular the Vision 350. Is there an extended image labrary available, or can i get some info on importing my own images from other software, for example microsoft paint. Regards, Rich. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 5, 2012 MVP 2021 Report Share Posted August 5, 2012 Have you looked at all the images that come with the software? They're located in: C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\ImagesC You can also use any image of your own if it's in .bmp or .jpg format. Make sure it's the right pixel size before you try to use them in your project. Joe T. Quote Link to comment Share on other sites More sharing options...
rich Posted August 18, 2012 Author Report Share Posted August 18, 2012 Thanks Joe, Tried a few of my own in paint, will have to play around with the pixels etc a bit, to achieve good images. Rich. Quote Link to comment Share on other sites More sharing options...
