viper_lasser Posted August 16, 2012 Report Share Posted August 16, 2012 During booting my plc I had pressed screen and I choose option "Boot to factory default". After that Touch Screen is not working anomore. I can download project, monitor variables but I cant get into diagnostic mode ? What should I do to activate Touch Screen ? Quote Link to comment Share on other sites More sharing options...
curtharrington Posted August 17, 2012 Report Share Posted August 17, 2012 you may need to redownload the OS Quote Link to comment Share on other sites More sharing options...
Ofir Posted August 19, 2012 Report Share Posted August 19, 2012 Hi, What do you see on the HMI? After downloading applicaiton, do you see the right display? If you are able to communicate with the PLC, go online (debug mode) and check if SB16 turns on when touching the screen. Quote Link to comment Share on other sites More sharing options...
