How to create a slider bar
  • MVP 2014
I am not aware of a built-in way.
When you say "any way" - you can use the direct draw functions to create your own (Draw Line, Draw Pixel and Clear Rectangle). Also use SI40 and 41 to read the touch coordinates. You can then manually draw the slider bar based on where the user touches the screen.
What model PLC are you using?
  • 4 years later...
Here is how I ended up solving it. This application changes the display brightness by touching and sliding the Bar Graph left or right. The ladder logic would need to be adjusted for the actual coordinates of the slider bar. Note that I check to make sure the correct screen is being displayed and that the PLC is not in INFO Mode.Slider Bar.jpg
  • Upvote 2
