AZ1975 Posted September 5, 2012 Report Share Posted September 5, 2012 MyProj.pdfJust returned from South America, where the project take place, about the process: After the extracting the juice from the citrus they take the peels, chop them, make a mash, filter, and concentrate the liquids.(of course is more complicate than that...) The PLC: V1210 with Ethernet Card to control the process and programming remotly. About 150 I/O's, analog inputs to control temps, levels, VSD's. analog outputs for VSD's too. All objects in the process are programmed logicaly as FunctionBolcks, practically each object is a soubroutine.(objects are: motors,valves,analog signal,level switch,etc). Enjoy it. AZ1975 Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted September 5, 2012 Report Share Posted September 5, 2012 Very cool! thanks for sending this in Quote Link to comment Share on other sites More sharing options...
