Jassa Posted September 7, 2012 Report Share Posted September 7, 2012 What is the function of the button "Apply" on the "Replace operand" window? Visilogic V9.4.0 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted September 7, 2012 MVP 2021 Report Share Posted September 7, 2012 "Apply" has the same function as "OK" without closing the Replace window. Use it if you want to do multiple Replace operations. Joe T. Quote Link to comment Share on other sites More sharing options...
Jassa Posted September 10, 2012 Author Report Share Posted September 10, 2012 Thanks, the issue was caused by the fact that it was not working at the moment. The window remained open, but operand is not changed. But today it`s all right. PC tricks probably.... Quote Link to comment Share on other sites More sharing options...
