External Moderators tmoulder Posted October 15, 2010 External Moderators Report Share Posted October 15, 2010 I've got a vision 350 I want to change the key labels on. I downloaded the data sheet on this, and it seems there should be a tab to grip to pull out the old F1-F2 label strip and insert my own. The only problem is - there's no tab. Am I supposed to be able to insert my strip in front of the existing one (it seems like it doesn't want to slide up in there), or is the tab trapped inside the housing somewhere? Thanks, TM Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted October 17, 2010 Report Share Posted October 17, 2010 Hi, The current V350 don't have default tab to grip and pull out. It was causing some problems so Unitronics desinge a new keyboard with printing in the internal layer. You can use your custom slide (which made according to the document) and insert it from the slot nearby the expansion port. BR, Reuven, Quote Link to comment Share on other sites More sharing options...
External Moderators tmoulder Posted October 18, 2010 Author External Moderators Report Share Posted October 18, 2010 Thanks! That's what I needed to know. TM Quote Link to comment Share on other sites More sharing options...
