rookieprogrammer Posted December 16, 2012 Report Share Posted December 16, 2012 Is there a "best method" way of cleaning the plug in pins (especially the female end)? My V200 plugged into the back of a V570 works intermittently. Sometimes an output will stop working. I can turn PLC off, unplug V200 and plug it back in, and it starts working. Sometimes I can just press the back of the V200 and it starts working. Is this a a quality problem of the connector, or does it need cleaning? The PLC is new although I have had it over a year. Went to training so I could learn Unitronics. By the time I'm now trying to get things to work, out of warranty. Sometimes the port 1 of the com link stops working and I have to transfer plug to port 2. Did I get a unit built on Monday morning? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted December 16, 2012 MVP 2021 Report Share Posted December 16, 2012 It sounds like you have more than one connector problem. Look carefully at Port 1 and at the pins on the V200 module - are they corroded (blue) at all? Contact your distributor - Unitronics has a two year warranty. Either way they they should be able to help you. FWIW, Israel starts the work week on Sunday. Joe T. Quote Link to comment Share on other sites More sharing options...
rookieprogrammer Posted December 16, 2012 Author Report Share Posted December 16, 2012 Thanks, Joe! Quote Link to comment Share on other sites More sharing options...
