jdawalt Posted December 20, 2012 Report Share Posted December 20, 2012 hello, with most of the Software i use, the timming functions come with alternate bits that represent the different modes of the timer stages IE: Timer TIming /Timer Enabled/Timer Done. i use alot of debounce timers in my software to obtain the "Debounce" its simply latches on a bit true for the duration of the timer, which is where the Timer Timing bit comes into play. Does the U90 Software has those features with the timers or an alternative way to create a debounce timer. all I can find is the "Done" bit. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted December 21, 2012 MVP 2021 Report Share Posted December 21, 2012 Unitronics does not have a complete set of bits to go along with the timer. You'll have to roll your own by picking an MB that's enabled with the timer coil but blocked by a NC of the timer done. This will achieve what you're looking for. Joe T. Quote Link to comment Share on other sites More sharing options...
