lawry Posted April 5, 2013 Report Share Posted April 5, 2013 Hi, Pl let me know if the expansion cable for EX A1 & EX A2 is the same. Can I safely replace the EX A1 with EX a2 using the same cable? Thanks Lawry Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted April 5, 2013 MVP 2014 Report Share Posted April 5, 2013 Hello, The cables are very different, so the cable must be changed if the module is changed. Also note that the cable for the EX-A2X has markings on each end to indicate which way it must go. Quote Link to comment Share on other sites More sharing options...
lawry Posted April 5, 2013 Author Report Share Posted April 5, 2013 Thanks Simon. Quote Link to comment Share on other sites More sharing options...
