TozoM8 Posted April 17, 2013 Report Share Posted April 17, 2013 Can I mix inputs into the drum sequencer or timers only? Thanks Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted April 17, 2013 Report Share Posted April 17, 2013 Drum sequencer is used to set outputs only (Physical or MBs), so I don´t understand why you want to use inputs. Or do you mean using inputs to move between steps? Quote Link to comment Share on other sites More sharing options...
TozoM8 Posted April 17, 2013 Author Report Share Posted April 17, 2013 Yes. I have a ~40 steps procedure that requires a series of timers, but some steps requires an input from a scale ( weight reached) to advance to the next drum step. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted April 17, 2013 Report Share Posted April 17, 2013 Then you have to set duration time equal 0 to those steps you want to move by external signal rarther than by time. In ladder, you must use your own conditions and current step index drum sequencer to move next (Or desired) step Quote Link to comment Share on other sites More sharing options...
TozoM8 Posted April 17, 2013 Author Report Share Posted April 17, 2013 So if I leave those steps at 0 second then the drum stops. Now when my scale reaches the desired weight the scale rung needs to send a mb to "next step" on the drum to run again, right? Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted April 18, 2013 Report Share Posted April 18, 2013 Right, but you also must check current step to make sure you are moving to desired step. It´s also posible to jump to a step other than next one. Quote Link to comment Share on other sites More sharing options...
TozoM8 Posted April 18, 2013 Author Report Share Posted April 18, 2013 Got it, thanks! Quote Link to comment Share on other sites More sharing options...
