maitufte Posted April 29, 2013 Report Share Posted April 29, 2013 Hi, I’m trying to use Remote Operator to control my Vision 1210 PLC. The problem is that the remote system is about 5 seconds slow compared to the PLC. I am using an USB now, tried to use an Ethernet cable too, but couldn’t establish connection. Anyone who has had the same problem, or any tips and tricks to manage a "realtime" remote steering? Thank you in advance! Link to comment Share on other sites More sharing options...
Saragani Posted April 29, 2013 Report Share Posted April 29, 2013 I'm assuming it is a USB to Serial connection, am I right? I should be faster on Ethernet (Make sure that you enter the correct PLC name). The speed on Remote Operator, when accessing an Enhanced Color PLC is depended on the amount of variables on the screen. (More variables = more things to read and more things that can change). Link to comment Share on other sites More sharing options...
maitufte Posted April 29, 2013 Author Report Share Posted April 29, 2013 Thank you for a quick answer. Can't make the ethernet communication work. The message "Cannot communicate with the PLC with the specified UnitID!" pops up when im trying to get a UDP connection. Im not sure if im supposed to use UDP or TCP for this kind of communication? Hoping for some more help! Link to comment Share on other sites More sharing options...
AlexUT Posted April 29, 2013 Report Share Posted April 29, 2013 You have to use TCP Slave port configuration for OPLC, and TCP Call from VisiLogic. 1 Link to comment Share on other sites More sharing options...
