Bobkatt Posted April 30, 2013 Report Share Posted April 30, 2013 Hi I have built an application for monitoring registers on Unitronics PLC's using the Unitronics.ComDriver with vb.net Currently I am using the version compiled on 21/01/2013 I am able to read/Write to all registers on all devices except Jazz Timers When attempting to read either TP or TC Timers I get the following error: Index and length must refer to a location within the string. Parameter name: length The code I am using: Dim plc_request As ReadWriteRequest() = New ReadWriteRequest(0) {} Dim plc_read As ReadOperands = New ReadOperands() plc_read.NumberOfOperands = 1 plc_read.OperandType = OperandTypes.TimerPreset plc_read.StartAddress = 5 plc_read.TimerValueFormat = TimerValueFormat.SecondsFormat plc_request(0) = plc_read plc_con.ReadWrite(plc_request) -- error occurs on this line Dim plc_value As Object() = DirectCast((plc_request(0).ResponseValues), Object()) The error occurs on the line: plc_request(0) = plc_read I have also tried with plc_read.TimerValueFormat = TimerValueFormat.TimeFormat I appreciate any help you can provide Thanks Quote Link to comment Share on other sites More sharing options...
Saragani Posted May 1, 2013 Report Share Posted May 1, 2013 Hi, it appears that the U90 timers are different from the Vision timers. While the vision timers have the Preset and Current stored in an Int32, the U90 timers are stored in an Int16 where the first 14 bits (LSB) are the value and the 2 MSBs are the resolution. The Communication Driver fails on reading the timers preset/current on the Jazz or M90/91 PLC since it expects 8 characters and gets only 4 (this is why you get the exception of trying to part of strings out of its bounds)... U90/91 and Jazz PLCs also does not support setting Current and Preset values using PCOM (while the Vision PLC does). I'm not sure if this issue will ever get fixed. Since Unitronics share the sources of the communication driver, then you can change the code in order to fix it, or you can use the SendString command in order to sent Read Timer Preset/Curremt commands to the Jazz PLC, and use the reply you got from the PLC in order to get its value. For example: plc_con.SendString("GP000501") 1 Quote Link to comment Share on other sites More sharing options...
Bobkatt Posted May 5, 2013 Author Report Share Posted May 5, 2013 Sorry, but not having much luck with this, I changed the code to use: plc_con.SendString("GP000501") instead of plc_con.ReadWrite(plc_request) but got no reply from the Jazz Are you able to provide more detail about the string to be sent to the plc? Thanks Quote Link to comment Share on other sites More sharing options...
Saragani Posted May 5, 2013 Report Share Posted May 5, 2013 It should work. I have tested it on a M91 PLC. It is the same command that is being sent which doing your code: Dim plc_request As ReadWriteRequest() = New ReadWriteRequest(0) {} Dim plc_read As ReadOperands = New ReadOperands() plc_read.NumberOfOperands = 1 plc_read.OperandType = OperandTypes.TimerPreset plc_read.StartAddress = 5 plc_read.TimerValueFormat = TimerValueFormat.SecondsFormat plc_request(0) = plc_read plc_con.ReadWrite(plc_request) -- error occurs on this line Dim plc_value As Object() = DirectCast((plc_request(0).ResponseValues), Object()) 1 Quote Link to comment Share on other sites More sharing options...
