jimbo Posted May 11, 2013 Report Share Posted May 11, 2013 I am using a V130 with analog inputs from two flowmeters(4-20mA). I am displaying the flowrates from each meter. I need help adding the flowrates from the two flowmeters and displaying the total flowrate. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 11, 2013 MVP 2021 Report Share Posted May 11, 2013 Use the internal 1 sec pulse (SB 13) to continuously add the instantaneous flowrate value to an accumulating ML. You didn't give any details on your flowrates, so I'll assume you're reading gallons/min. If you divide your ML by 60 in this case, the result will be your total flow in gallons. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
jimbo Posted May 22, 2013 Author Report Share Posted May 22, 2013 Thanks, worked fine Quote Link to comment Share on other sites More sharing options...
