Gabriel Franco Posted May 26, 2013 Report Share Posted May 26, 2013 Hello all, What does exactly mean warning 63 and how can affect me if I want to write data tables to SD? Description given in compile tab is not clear enough to me.Attached picture. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted May 28, 2013 Report Share Posted May 28, 2013 Hi Gabriel, Thank you for pointing us to this. Unfortunately this message appears even if there is an even number of Bytes in string. But it should indicate odd number of Bytes. This will be corrected in next release of VisiLogic. You should keep number of bytes in string to be even (2,4,6,8, etc. Bytes). Then it will be no problem. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted May 28, 2013 Author Report Share Posted May 28, 2013 OK, thanks. Just for the record, I added another column (Byte type, part of Project, 1 element) and warning did not come up again. Quote Link to comment Share on other sites More sharing options...
