SteelBlue48310 Posted June 5, 2013 Report Share Posted June 5, 2013 Is there a way to set the PLC to run in a 'step' mode for debugging purposes to make it go one net at a time and watch it via the Debug screen? I seem to have a situation where something is happening faster than I can monitor with the normal Debug screen. Quote Link to comment Share on other sites More sharing options...
dan Posted June 7, 2013 Report Share Posted June 7, 2013 Hello, There is a troubleshooting tool that will allow you to view a portion of the ladder. The tool must be placed in the ladder before the option will be available. It is located under util>debug>online-point and interval. thanks, Quote Link to comment Share on other sites More sharing options...
lawry Posted June 7, 2013 Report Share Posted June 7, 2013 Hi, SteelBlue, What PLC are you using? You can do as Dan suggested only with Visilogic which is the software for Vision series. If u are using a M90 or Jazz, then the software is U90 & this does not have the feature u are asking for. I too am waiting to be enlightened on this topic. Lawry Quote Link to comment Share on other sites More sharing options...
SteelBlue48310 Posted June 7, 2013 Author Report Share Posted June 7, 2013 It is a M91. Oh well... I might have found the issue anyway, but it would be cool to single-step the code. Thanks Dan and Lawry! Quote Link to comment Share on other sites More sharing options...
