Gabriel Franco Posted June 20, 2013 Report Share Posted June 20, 2013 I noticed differences in technical specs (Memory, colors, ) for V570 between Web information (http://www.unitronics.com/plc-hmi/plc-vision-enhanced/v570-#tab10) and pdf file (http://www.unitronics.com/Downloads/Support/Technical%20Library/Vision%20Hardware/Vision500%20-%20Specifications/V570-57-T20B-T40B-J_TECH-SPEC.pdf). Which one is correct? Quote Link to comment Share on other sites More sharing options...
Alexander Posted June 20, 2013 Report Share Posted June 20, 2013 Which discrepancy did you see with the memory? Both list the 2MB for logic and 12MB for images. As for colors the 64K is represented at approximately1024 per K which would give the exact number at 65,536 colors. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted June 21, 2013 Author Report Share Posted June 21, 2013 Web page, under Specifications: •Application Logic: 2MB ; Fonts: 1MB ; Images: 6MB HMI •5.7" 256-Color Touchpanel, QVGA TFT display (or CSTN) Web page under series overview, as well as PDF: - 2MB Ladder code application memory (plus 12MB for images and 1MB for fonts) Quote Link to comment Share on other sites More sharing options...
