Petros Posted July 6, 2013 Report Share Posted July 6, 2013 Hello, Can anyone suggest a way to convert a value into a pulse output? I need to convert a numerical value range into a predefined frequency range pulse. Thanks Petros Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 7, 2013 MVP 2021 Report Share Posted July 7, 2013 Use the PWM block - FB's->PWM->Scan. You'll have to do some conversion as the input the block is in units of 2.5 ms, and set your duty cycle to 500 (50%). If you have further questions give us more specific details about your application. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
