kdcui Posted August 10, 2013 Report Share Posted August 10, 2013 I'm just wondering if this is valid, or if there is an easier way to do this?Let's say I have a bit in an MI that I would like to set. With an MB, I would do something such as: COMMENT: Enter Sets MB 10 MB 10 stays set until ESC is pressed SB ENTER Key MB 10 --| |------|P|----------( ) | | MB 10 SB ESC Key | --| |-----| \ |------- Would the following work with an RLO and an MI? Is there another way to accomplish this? COMMENT: Store state of MI 400 Bit 10 in MB 100 ____________ ------------| TEST BIT |---------- | | MI 400 | A C | MB 100 | | | | # 10 | B | |____________| COMMENT: Enter Key is pressed. One shots the RLO. Next scan comes around, updates MB 100 with the state of MI 400, Bit 10. MI 400 Bit 10 stays on until ESC is pressed. SB ENTER Key ______________ --| |------|P|------------------| RLO | | | | | MI 400 | A | MB 100 SB ESC Key | | | --| |-----| \ |------- | | #10 | B | |______________| Thanks. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 14, 2013 MVP 2021 Report Share Posted August 14, 2013 Two things come to mind- the BITS->NUM block and the Toggle Bit block. What's the rest of the story of what you're really trying to do? Joe T. Quote Link to comment Share on other sites More sharing options...
kdcui Posted August 15, 2013 Author Report Share Posted August 15, 2013 Joe, This is related to the valve program I mentioned in my other post. Basically I want the status / config of each valve to reside in an MI. However some of the logic uses bits common to each instance of the loop, and needs to do a check (read the new MI so to speak) before performing certain actions. I also like to avoid using set / reset if I can avoid it. Example (psudeocode): If VALVE OUTPUT BIT = 1 AND CLOSE CMD = 0 Then VALVE OUTPUT BIT = 1 In this case the OUTPUT BIT is a buffered output that resides in my valve word (MI). Eventually this bit will go to a corresponding O address. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 18, 2013 MVP 2021 Report Share Posted August 18, 2013 Have a try at writing your code and then post it. We can take a look at it and re-post with suggestions. Joe T. Quote Link to comment Share on other sites More sharing options...
kdcui Posted September 5, 2013 Author Report Share Posted September 5, 2013 Hi Joe,So I seemed to have figured out the answers to my questions during my debug process. My code is 90% finished, I just need to write some data logging.In case you are interested in seeing what I was trying to accomplish, here is my code. It is for lifecycle testing up to 12 valves. It logs if the valve has failed based on failure to see (or not see) flow downstream of each valve via a flowswitch. I indirectly loop through all (up to) 12 valves and store their configuration and status in bits in an MI register. During each loop I:use RLO to set or latch bits in the MI indirectly.used Test Bit to look at the status of each bit pass the output status to the output (O) register for the valve. There is a bunch of other stuff going on but those things were basically the root of my questions.Thanks for the help.Kris Valve Testing.vlp Quote Link to comment Share on other sites More sharing options...
