Count Posted August 18, 2013 Report Share Posted August 18, 2013 Hey everyone I'm trying to be able to change my temperature set point from my HMI, without using a PID loop. Essentially, ive used the 'Store Direct' function to save my chosen set point to an MI. I will then use the HMI keypad to enter in my new set point. My problem is that the new set point doesn't save when i enter it. -------[#240]--{STORE DIRECT}----[MI 4]--------- Sorry i cant draw it any better, but im sure you understand. Cheers Quote Link to comment Share on other sites More sharing options...
Count Posted August 18, 2013 Author Report Share Posted August 18, 2013 Problem SOLVED Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 18, 2013 MVP 2021 Report Share Posted August 18, 2013 What did you find? Joe T. Quote Link to comment Share on other sites More sharing options...
