TozoM8 Posted October 14, 2013 Report Share Posted October 14, 2013 I have a drum that I have to display the RPM. It has 8 magnets and a Hall sensor. I can convert the 8 signal to 1 rpm with linearization, but how do I display it as rpm instead of just an increasing number until I reset it? Any help would be greatly appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
Jerin Posted October 14, 2013 Report Share Posted October 14, 2013 Hi, Use High speed inputs. Detailed example is given in Visilogic(if vision series PLC.) as well as U90 ladder(if M90 series PLC). in U90 ladder. goto: help-> Sample U90 projects-> Motion Control folder-> motor speed.U90. In visilogic. help-> Examples-> Version 900-> Project Examples-> HSC_HSO folder-> V570_Frequency-precise meter.vlp ............. Quote Link to comment Share on other sites More sharing options...
TozoM8 Posted October 15, 2013 Author Report Share Posted October 15, 2013 Thank you! Quote Link to comment Share on other sites More sharing options...
