KAMAMT Posted October 31, 2013 Report Share Posted October 31, 2013 Hi, I'm still new to this so apologies if this is a simple fix. I'm using a V570 OPLC to send pulses to a stepper driver which in turn drives a stepper motor. I have it set up right now so that my O0 and O1 are set to npn so I can run them at higher frequencies. O1 is configured for High Speed Outputs (Step Control) and sends steps to my stepper driver. O0 simply sends a signal to my driver to reverse direction when I want to jog backwards. Right now I can run the system once but I want to be able to jog as often as I would like. I have tried two ways of addressing this problem but neither have worked. The easiest way would be for me to reset my current position DW, to 0 after jogging. When I do a store command after jogging however, nothing happens and I still retain my current position. The other option would be to send additional run commands. When I have multiple nets that have a coil to my run MB however, the system does not work at all. I am only able to jog when I have my run MB located in only one net. I would be thrilled if there is a way to reset current position DW (in step control high speed output) to 0. Sorry if this does not make sense. I can try to explain more if needed. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted October 31, 2013 MVP 2021 Report Share Posted October 31, 2013 Post your code. Joe T. Quote Link to comment Share on other sites More sharing options...
