plcguru Posted February 12, 2014 Report Share Posted February 12, 2014 I'm having trouble installing Unilogicsetup1.5.exe on my Windows 7 machine. I have Visilogic installed and have created several programs without issue. Now I am trying to install the new Unilogic software to no avail. Here is the error message I am receiving. "The contents of this file cannot be unpacked. The executable you are attempting to run has been corrupted. Please obtain another copy of the file, verify its integrity, and try again." Here is the URL from which I have obtained the file. http://www.unitronics.com/support/downloads Thank you, plcguru Quote Link to comment Share on other sites More sharing options...
MVP 2022 Joe Tauser Posted February 14, 2014 MVP 2022 Report Share Posted February 14, 2014 I had that problem. If you have a file compression/decompression program such as Winzip use it to manually unpack the file into its components. Joe T. Quote Link to comment Share on other sites More sharing options...
