jonask Posted March 12, 2014 Report Share Posted March 12, 2014 I am trying to set up a level controller on a M91-2-UA2 and I'm having problems with the output of the P part of the regulator(Kp wich is shown in SI120 for loop 1). With the proportional band set to 100% the output should be the same as the error, but in my program this only works up to 50%, if the error is 51% or more the output is 100%. Here is a list of error value and the output form the controller: error output 0% 0% 25% 25% 50% 50% 51% 100% 75% 100% 100% 100% This is with booth I and D set to 0. Is there a parameter that can set this kind of behavior? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted March 13, 2014 MVP 2021 Report Share Posted March 13, 2014 The proportional band is acting like it's centered around the setpoint, with 50% on either side. According the Help, your logic should be valid. But it's not acting the way it should. Try setting the proportional band to 200%. What are the values of your PV Hi and Lo limits? Joe T. Quote Link to comment Share on other sites More sharing options...
jonask Posted March 13, 2014 Author Report Share Posted March 13, 2014 I have tried to simulate the program with the proportional band at 200%, this is my results: error output 0% 0% 50% 25% 100% 50% 101% 100% With this setup I will never get the jump in output because the error will never bee 101%, but 200% proportional band is too slow for the process and the regulation will not work. Here is a image form the documentation showing how the output of the proportional band should work and how mine is working. The red line is how it should work, mine works like the green line, which I have added to the image. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted March 19, 2014 MVP 2021 Report Share Posted March 19, 2014 Let's go back to my other question on what the PID configuration values are. Can you list these or better yet, upload your program? Joe T. Quote Link to comment Share on other sites More sharing options...
